If Extreme Networks makes a new version of the Fabric IPsec Gateway available,uninstall the original virtual service, and then install the newer virtual service.
  • Ensure the new virtual service image version is compatible with the NOS release that runs on the switch. Only use the virtual service image version that is posted with the NOS release image. For more information about image files in a release, see VOSS Release Notes. If necessary, upgrade the NOS image before you upgrade the virtual service image.
  • Note
    The Fabric IPsec Gateway image includes no integrity check. Use SCP to copy the file to the switch and confirm the file size before installation.
Steps in this procedure include examples or links to background procedures if you are unfamiliar with how to complete a particular step.
  1. Within the VM, save the configuration. For more information, see Save Running Configuration to a File.
    Switch:1>enable
    Switch:1#configure terminal
    Enter configuration commands, one per line.  End with CNTL/Z.
    Switch:1(config)#virtual-service figwOld console
    Connected to domain figw5.2 Escape character is ^Y
    FIGW> save config
    File already exists, do you want to overwrite [y/n]: y
    FIGW>
  2. Copy the configuration files (*.cfg), the shadov.txt file, which is an encrypted file that contains the authentication keys for the IPsec tunnels, and the default-config-file.txt file from the VM to intflash within the NOS. For more information, see Run a VM command from Network Operating System (NOS) CLI and Copy VM Files.
    Switch:1(config)#mkdir figw
    Switch:1(config)#virtual-service figwOld exec-command "ls /home/rwa/configs/"
        config.cfg
        figw.cfg
        figw_cli.log
        new.cfg
        shadov.txt
    Switch:1(config)#virtual-service copy-file figwOld:/home/rwa/configs/config.cfg /intflash/figw/config.cfg
    Switch:1(config)#virtual-service copy-file figwOld:/home/rwa/configs/new.cfg /intflash/figw/new.cfg
    Switch:1(config)#virtual-service copy-file figwOld:/home/rwa/configs/figw.cfg /intflash/figw/figw.cfg
    Switch:1(config)#virtual-service copy-file figwOld:/home/rwa/default-config-file.txt /intflash/figw/default-config-file.txt
    Switch:1(config)#virtual-service copy-file figwOld:/home/rwa/configs/shadov.txt /intflash/figw/shadov.txt
  3. Verify the file copy:
    Switch:1#ls figw/
    Listing Directory /intflash/figw/:
    drwxr-xr-x 2 0 0 4096 Jun 17 13:46 ./
    drwxr-xr-x 31 0 0 4096 Jun 17 13:43 ../
    -rw-r--r-- 1 0 0 851 Jun 17 13:44 config.cfg
    -rw-r--r-- 1 0 0 8 Jun 17 13:46 default-config-file.txt
    -rw-r--r-- 1 0 0 0 Jun 17 13:45 figw.cfg
    -rw-r--r-- 1 0 0 851 Jun 17 13:45 new.cfg
    -rw-r--r-- 1 0 0 32 Jun 17 13:45 shadov.txt
  4. Disable the virtual service:
    no virtual-service WORD<1-128> enable
  5. Uninstall the virtual service:
    virtual-service WORD<1-128> uninstall
    When you uninstall the original virtual service, the system removes the complete virtual service configuration from the configuration file.
  6. Install the virtual service package using the new image:
    virtual-service WORD<1-128> install package WORD<1-512>
  7. Reconfigure the virtual service. For more information, see Configure a Virtual Service.
  8. Copy the files you saved from the old VM to the same folder path in the new VM:
    Switch:1(config)#virtual-service copy-file /intflash/figw/config.cfg figwNew:/home/rwa/configs/config.cfg
    Switch:1(config)#virtual-service copy-file /intflash/figw/figw.cfg figwNew:/home/rwa/configs/figw.cfg
    Switch:1(config)#virtual-service copy-file /intflash/figw/new.cfg figwNew:/home/rwa/configs/new.cfg
    Switch:1(config)#virtual-service copy-file /intflash/figw/shadov.txt figwNew:/home/rwa/configs/shadov.txt
    Switch:1(config)#virtual-service copy-file /intflash/figw/default-config-file.txt figwNew:/home/rwa/default-config-file.txt
  9. Verify the file copy:
    Switch:1(config)#virtual-service figwNew exec-command "ls /home/rwa/configs"
    config.cfg
    figw.cfg
    figw_cli.log
    new.cfg
    shadov.txt
  10. Reboot the Fabric IPsec Gateway VM. For more information, see Reboot Fabric IPsec Gateway VM.
    Tip
    Tip
    As an alternative, you can disable and reenable the Fabric IPsec Gateway virtual service.
  11. Verify the running configuration of the new VM matches the configuration of the old VM:
    Switch:1(config)#virtual-service figwNew figw-cli "show running-config"
    set global ipsec-tunnel-src-vlan 30
    set global ipsec-tunnel-src-ip 30.30.30.2/24
    set global lan-intf-vlan 100
    set global lan-intf-ip 100.100.100.2/24
    set global lan-intf-gw-ip 100.100.100.102
    set global fe-tunnel-src-ip 102.102.102.102
    set global wan-intf-gw-ip 30.30.30.102
    set global mtu 1950
    set global services sshd enable
    set ipsec 104 auth-key ******
    set ipsec 104 responder-only true
    set ipsec 104 fe-tunnel-dest-ip 104.104.104.104
    set ipsec 104 fragment-before-encrypt enable
    set ipsec 104 admin-state enable
    set ipsec 105 auth-key ******
    set ipsec 105 responder-only true
    set ipsec 105 fe-tunnel-dest-ip 105.105.105.105
    set ipsec 105 fragment-before-encrypt enable
    set ipsec 105 admin-state enable
    set ipsec 107 auth-key ******
    set ipsec 107 responder-only true
    set ipsec 107 fe-tunnel-dest-ip 192.168.22.107
    set ipsec 107 admin-state enable
  12. Remove the original image from the /var/lib/insight/packages/ directory on the switch:
    remove WORD<1-255>
